brake performance rotors rusted out in 3 months.
Chiggy
Kansas City, MO
Don't paint your rotors. You should have bought the Zinc coated ones. You'll never get the rust off there to have a good surface paint will stick to and the paint will wear off eventually making them look worse that just being rusty.
Chiggy
Kansas City, MO
If that was true they wouldn't be rusting. I think you've been lied to. Or they sent you the wrong parts. Mine are 2 years old and they look the same as the day I put them on.
rippinitup
rippinitup
NY.
I've gotten the dimpled drilled and slotted rotors with the "black zinc" coating. I called them and they told me it's metal it's going to rust.
NJ04HOE
Paterson, NJ
They definitely lied to you, best option is paint and never buy from them again
rippinitup
rippinitup
NY.
The rotors were black when I got them though. So I don't understand what's going on.
rippinitup
rippinitup
NY.
Hey are your rotors more of a "silver" color or the dark type of metal like mine? They claim the rotors is supposed to look like this.
Mine.
Chiggy
Kansas City, MO
Mine are silver. The hats are silver for the most part as well still. There's a little bit of brake dust on them that has corroded a teeny bit but it's nothing like what you've got going on. Zinc is a sacrificial metal they dissolve in a bath and through a galvanic process it coats the parts. It's going to take a while for a good coating to all rust off and leave bare steel to rust like that. Zinc isn't usually dark so I don't know how they did that one either. I got my kit from powerstop for both of my vehicles. With my Tahoe I got the kit for the 07+ tahoe with pads and went to the parts store and got new calipers and brackets. It stops like a champ now.
Red Rider
No way you can clean that with a brush. Just sand blast them.
High temp paint?? Don't you need caliper paint? I never had much luck with plain high temp paint. Or maybe that was with exhaust :)
Red Rider
BTW, if you paint them, you void the warranty. I did that with a caliper i bought. They immediately started leaking. So i brought them back. They said "no can do". I had to take all the paint off before they would accept it back. That was AdvancedAuto.
3ddi3
