Blackbear Performance Review
Fless
Super Moderator
Elev 5,280
So it’s been interesting. I’ve been doing a good bit of “general” maintenance (will post in the 3500 thread I have) but VIN lookup at the parts store has the question about flex fuel or non-flex fuel engine. I believe my truck to be non-flex as it was a fleet vehicle and came with a sticker “GASOLINE ONLY”.
I do not have a factory sticker indicating anything else.
That's pretty conclusive that it's not a FF system.
Geotrash
Dave
Richmond, VA
If you have a bidirectional scanner and use the mfr's codes by VIN (not generic OBD) is there a fuel composition or alcohol content value, or a reset function?
So here's what I found with HP Tuners, using their scanner app. Alcohol content was not a default channel for the app's home screen, but I was able to add it and then scan the ECU to see if there was any data available there. Sure enough, there is. Now I don't know if it's a calculated value based on O2 sensor data, or an actual hardware sensor value, but at least the ECU is capturing alcohol content data as a percentage. And the value seems plausible. Note, the ignition was on but the engine wasn't running for the screenshot below.
Fless
Super Moderator
Elev 5,280
I can't imagine that there is a physical sensor on it, so I would bet it's a calculated percentage. They dropped the physical sensor from the GMT800s around 2005 or so.
Geotrash
Dave
Richmond, VA
Thanks, Steve. I think you’re right about not having a physical sensor, but I guess the question is still open as to whether or not it’s actually a stealth flex fuel truck.
Fless
Super Moderator
Elev 5,280
Curiously, gmauthority says it's FF:
I would be inclined to do a little test with some E85 -- know your fuel trims with E10 first, then maybe mix 1/3 E85 (probably E50 or E70 at the pump) with 2/3 gas and see 1) if the STFTs go way positive, or settle down to a good value and 2) see what HP Tuners reads for alcohol content. And not a full fillup, just less than 1/2 a tank if it becomes an issue.
EDIT: I take that back, didn't read the fine print. Article says FF in the Savanna and Express only. :confused:
mikeyss
Longmont, Colorado.
It's odd that this article says the L96 has cathedral port heads, but those came with the 823 rec port heads.
B
Bigburb3500
What is the physical difference between a FF and non-FF engine? Maybe a dumb question but I’m wondering if the “stealth” feature is there but the difference could be injectors or something else buried deep into the truck.
Maybe?
Fless
Super Moderator
Elev 5,280
Maybe?
As I understand it from a GMT800 perspective, larger fuel injectors, a fuel pump that can pump more volume, and an E85 fuel table in the ECM. I'd be curious what others think the differences could be.
mountie
I gotta do the Blackbear ( I keep considering it)......
Making a right turn from a light ( get ahead of oncoming traffic driving over the speed limit).....
( Screw them... they're speeding )... I have good acceleration, but the '05 Yukon is confused, with "how much throttle / gear it should be in".
It's like the ECM doesn't think fast enough......
silverado15
