inkadink
I took the front wheels off my 1997 tahoe yesterday to check the pads. It looks like I should change out the pads at least. Upon further investigation I see that my brake bleeders are rusted off and they are round. Also the brake rotors are wearing uneven and look like they would need to be turned.
I looked up brake parts for my hoe and I see that the calipers are really cheap (15-25 dollars a piece) if I buy rebuilt ones but new oem are very $spendy$. The same holds true for for the brake rotors.
I figure why not just replace the rotors and calipers and pads all at once and make everything like new again or should I drop 5x plus the money on delco oem stuff to get the job done?
Also,, the brake pads are a bit of a concern for me as well. Buy semi-metallic or go for the full on "quality" ceramics? Will I see better longevity and consistency with ceramics in regards to rotor wear?
It is all to easy too do all of this at once if I am already in there to do the pads. Should I just buy the inexpensive parts and just change it all or do OEM have thier merit and likewise the $$$?
Thank-you for your replies and ideas as I appreciate it very much.
