01subCT
I only have fronts..I wanna do rears for looks tho..I have 24s so u can see the disc easy
Can you replace just the front with slotted discs or do you have to do the rear too?
Chris, another member already uses that pic. mijohnst uses that pic but not with the words on it.![]()
I am thinking about upgrading my brake on my 06 tahoe to the 2007 version my understanding is i need calipers , brackets , rotors and pads any thing else ?? have you done this ?Cheap upgrade is 07 up rotors and calipers with brackets.noticable difference.get a good aftermarket pad..good to go
I am not seeing where you say what size wheels you have on your vehicle now, but if I am not mistaken, you will need at least 17’s for the NNBS brake upgrade.Good advise on replacing the hoses i will most likely go stock i am going to take the easy route and just order the 07 caliper rotor pad kit from powerstop it also includes the brackets
