Broke hoe:(
Chevymyre
99 that just got a TuneUp and oil change with new pump is showing check gear light and knocking when accelerated. Never had a problem before this. Help!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
what kind of pump? and what is a check gear light? and finally what kind of knocking? bearings? combustion? flywheel bolts what?
C
Chevymyre
The check gears light has been coming on since the pump went out. Went to autozone and they said the knock could be clogged valves or a bad sensor because the gauge us still reading low when full. I'm honestly not sure what the knock could be, I'm new to working on cars but I'm no dummy. . . The pump I'm talking about is the oil pump. I just bought one from autozone yesterday
purple 'hoe
Green Bay, Wisconsin
So you just replaced the oil pump? You sure everything is put back together correctly?
Never heard of a "check gears" light in my life... Check gauges perhaps?
SunlitComet
OBS Jedi-Do Good
dude if you meant check gauges light and that happened after an oil pump change you better shut that thing down NOW! that light don't come on easily it is like a you are about to get F***** warning. And now I will say that knocking is a bearing that just got screwed.
---------- Post added at 09:30 PM ---------- Previous post was at 09:28 PM ----------
have the pressure verified with a mechanical pressure gauge in place of the vehicle one. NOW!
---------- Post added at 09:30 PM ---------- Previous post was at 09:30 PM ----------
if you have to go to a shop tow it.
ssrado85
Galveston
^ YEAH THAT ^ Sounds like he's High and dry to me if hes been driving like that and has'nt locked up there is prolly some serious damage.
purple 'hoe
Everything Sunlit said. You have major problems dude. And none of us can really help you with the very vague info you gave us so far
jcdenali
