Broke my antenna like a *******. Where to buy housing?
Michigan
IMG_9696.JPG IMG_9694.JPG Ok so I was trying to remove my antenna to add a antennax that I ordered. Instead of turning left my dumbass turned the wrench right. Got my righty and left confused in this case I guess. Anyways the antenna stripped right off with the threaded bolt or whatever is still attached to the antenna. So he threaded bolt that stick out of the housing got stuck into the old antenna. Hope this makes sense. What now? Can I order a new hoisin piece that will have the threaded bolt or do I have to go to a junkyard? Thanks
Michigan
Michigan
So I just watched these two videos on YouTube that really helped me out and gonna do this as soon as I locate a mount.
Only thing I'm worried about is making the same mistake someone else stated they made in the comment section saying that when they tried pulling the original antenna wire they broke the pin or what not. Hope it doesn't happen when I try. I am not a very good do it yourselfer. Smh
Fosscore
Just take your time, go slow, refer to a wealth of YouTube videos as needed and if it is out of your range of personal experience, then that's when spend too much time on TYF, you phone a friend or go to the mechanic. Good luck.
heavy02
