Before: rear knock sensor hole was full of water. Probably from my engine degreasing when I first got it in March. Got a CEL in December. I made the damn of RTV per GM TSB so any water should not fill the knock sensor holes. Although the front was dry the rear is usually the one to get wet since the engine slopes backwards.
I shouldn’t have to clean engine with water since I’ve replaced valley cover gasket and valve cover gaskets should stop any upper engine oil leaks.
Before:
Cam looks good from what I can see for 176k miles.
