Broken manifold
Matt06Yukon
Ok, maybe I'm missing something but if thats the last bolt you need to remove, can you remove the rest of them and then slide the manifold past the broken one? Then it'll be easier to remove once the manifold is gone. For some stupid reason, those broken manifold bolts are sorta common. I thought it was more on the 6.0 liters.
C
Cobra
Austin, Tx. area
everything is off. was not going to put headers on with a broken bolt in block. problem has been solved and long tube headers are now installed.
tony97218
