Dustin Jackson
- Joined
- Aug 9, 2018
- Posts
- 1,541
- Reaction score
- 1,739
Current goal: budget pavement "prerunner".
Hello everyone, I have decided to set my Tahoe up to be a pavement prerunner of sorts since it is clean and I have a Cherokee that I do all my off-roading in.
With my tahoe I will be mobbing over speed bumps, dips, humps, rail road tracks, and shit roads while being comfortable and without having to worrying about bottoming out.
In getting my Tahoe to a budget pavement "prerunner" I am attempting to maximize my ground clearance and wheel travel while also not absolutely destroying my suspension geometry.
In a pavement budget prerunner how does one find a balance of Ground Clearance, Wheel Travel, and Suspension Geometry?
So far I have pushed my lower control arm to a point where the angle isn't perfect but the ball joint isn't stressed. The tie rod angle could be better. The upper ball joint is perfect, not stressed a bit (good job RC on these arms they are great). The CV axle looks a little stressed but I have been thinking of removing them.
Down the road I will be moving to Fox coilovers for more wheel travel and articulation but for now I am wondering if there is anything I can do to my current setup to improve it.
How does this look? And do you have any recommendations on how I could better achieve my goal?
This is my front setup:
Rough Country Forged Upper Control Arms
Cut upper control arm bump stops
Factory height Bilstein 5100 shocks with Moog 81244 HD springs + a 2.5 inch spacer.
Here is my Tahoe:
Here is my Tahoe:
