jeffr630
Alright so I'm working on building a system thats slightly bigger than what I've had up until now so I'm treading into unknown territory.
Heres what I'm working with:
Head unit: JVC KWNT30HD (touch screen, DVD, nav, HD radio, BT)
Front stage
Skar Audio VXI65 components in front and rear doors
AQ 120.4 4-channel 120w/ch at 4 ohms
Subs
2 Skar Audio VVX-10 in a ported box
AQ 1200 monoblock amp (1200w at 1 ohm)
What I need help figuring out is the power. I'd rather not get a ** alternator because that seems to be the most expensive option. I was thinking of doing the big 3 upgrade but I dont know whether to do 4g or 0g, and I also cant find a write up or how-to anywhere.
Right now I'm thinking about running a second battery and running 4g wire for the positive and negative between the two batteries and 0g to the sub amp and 4g to the 4 channel. I want to run a wire for the ground because I've heard its a better ground than the chassis and I hate finding a good ground on the chassis. Normally for a 1500+ watt system I would run 0g wire but I figure with a second battery it would reduce the current between the two batteries.
What would you recommend for the second battery? Obviously it should be a deep cycle. I would like to find one thats around $150 or less, and I would like to put it under the middle seat next to the amps. I know this probably sounds unconventional but I was thinking about getting a miniature marine battery thats used for jet skis or trolling motors. I really don't need it to be a high end car audio battery. I'm also wondering about a battery isolator? I dont know the actual name for them but they're like a high current relay.
Any input would be appreciated, preferably from people who have experience with a bigger systems.
Front stage
Subs
