Buying Yukon with 6" Lift, have questions
Countryboy07
I'd buy it if it's mechanically sound. 138,000 is nothing for these vehicles. If I were purchasing, I'd leave the suspension lift alone, remove the body lift, and run a nice set of 20x12 on 33x12.5's.
H
HerbieHancock
Thank you for the info I don't know if the gears are Factory
01Konvict
Boats n Hoes
Raleigh/SML
:doublepuke::rice::grumpycat: Ok this Yukon needs all kinds of help!!!
@HerbieHancock alright dude lets get this started down the right path. It appears to be the Rancho 4" might be wrong but pretty certain. Being a SLT with factory tow hitch I'm assuming its 3.73 gears which is plenty for 33s. Here is the list of things that need to be done.
1. Ditch the wheels, flares, tube steps, body moldings, z71 stickers, Yukon and slt badges, and take off that 3" body lift
2. Get either 20x10 or 20x12 on 33x12.50R20 or 305/55R20
3. Add 1.5" body lift to clear tires if needed plus 1" rear coil spacer and crank up keys some to level with rear
4. New tail lights, headlights, corner lights, fog lights
5. Detail entire car with compound buff, polish, wax
H
HerbieHancock
The gears are Factory the transmission was rebuilt with a bigger torque converter I believe why should I take the body lift off I know the torsion bars measure 20 inches
H
HerbieHancock
I don't know if it has a body lift all I know is it has 20 inch torsion bars do you know what year they started putting 3rd row seats and them
Countryboy07
It does have a body lift... The 3rd picture you posted shows the spacer between the body and the frame, right above where your step is mounted.
