Buzzing sound from center console 110 outlet
Jeff_
Scottsdale, AZ & N. Idaho
Just curious if anyone else experiences a slight buzzing sound coming from the outlet on the center console when charging a laptop. I can’t imagine it’s good so I try to avoid it.
Wife’s laptop is a MacBook Pro and it uses a 96w power adapter so maybe it’s pulling too much power and that’s why it’s buzzing?
Any insight is helpful as she would love to be able to use and charge her laptop on the longer road trips we go on.
gtrslngrchris
Almost guaranteed to be coil whine from the charger or the inverter for the 110v outlet. Very common electronics problem and only an actual problem for your ears. If the same charger does not create the noise in other outlets my guess would be that the modified sine wave from the inverter is the cause. If the same charger makes the noise on other outlets with different power sources then it is the charger itself.
dexmann1
