C0237 Code
Tahoebigdog03
Hello I have a strange issue with my ABS light coming on when I hit a bump then the doors unlock and the check engine light blinks but don't stay on. Now and then the service brake system will pop up in the information Center but not always. Also there is loss of power when all this is going on like slow aceleration. This has been going off and on for last few days but like I said its of and on. So today I got the code pulled its C0237 Chevrolet - Erratic Rear Speed Signal.
Thanks guys if anyone knows any suggestions
cashflow50
I’m bumping this thread. I have the same issue and it just started this morning while driving to work. Anyone has any ideas of how to repair this issue?
Johnw_3
What ended up being the problem because I'm having same issue and going to replace the rear vss and hope it's the problem also looking for a bad wire on top of transfer case
Neither of those members have been on here in at least 5 years. I wouldn't expect an answer from either one.
Johnw_3
Thank you I think I ended up finding the issue with wires running across the top of transfer case
Johnw_3
Test drove it again the search continues looking at encoder ring now in transfer case
If you were to use a capable bidirectional scanner, it would show the speed sensors (there may be as many as three for the tranny and transfer case, depending on your setup) and would also show the commanded vs. actual positions of the 4wd modes so you wouldn't be groping in the dark.
Johnw_3
I dug deep into it with scanning and everything was looking good. Went back and double checked grounds. My first try I guess I didn't check it to well because i found a very bad ground on top of the motor on the back side that failed miserably. It's the main ground for the pcm causing all my problems. That thing was hanging on by insulator and would move around going over a bump
jdelasko
