Calculation Formula with Towing Capacity when adding bigger RIMS
longstand
Wanted to find out how much Towing capacity I'm losing with my 24" rims?
My towing is 6500 Pounds MAX.
I search this forum before i posted
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Does it not stand reason that as long as the total diameter is the same and weight ratings of the tire-wheel combo are equal you should not loose any capacity?
longstand
longstand
DUHHHHH!!! was a born yesterday? i think so, sometimes i should ask my self my own question ehh!
sorry this is a waste of Thread for such stupid question. LOL
It just make sense to me now, it dont matter what kinda rims you have. it all matter the TOTAL diameter with the Tire and rims install
bowtiefreak
No Quarter
Near Philly
Larger, heavier wheels make for more rolling mass directly effecting braking though. But as for load capacity...the suspension is the same, just make sure the tires are rated properly.
longstand
longstand
Door Count 4 doors
Maximum Cargo Volume 118.2 cu.ft.
Exterior Length 201.4 "
Exterior Width 76.8 "
Exterior Height 74.0 "
Wheelbase 118 "
Front Tread 63 "
Rear Tread 64 "
Turning Radius 20.4 '
Gross Vehicle Weight Rating 6,800 lbs.
Curb Weight 5,867 lbs.
Front Gross Axle Weight Rating 3,600 lbs.
Rear Gross Axle Weight Rating 3,750 lbs.
Payload 933 lbs.
Max Trailer Weight 6,500 lbs.
Front Legroom 41.7 "
Rear Legroom 36.4 "
Front Headroom 39.9 "
Rear Headroom 38.9 "
Front Hiproom 59.9 "
Rear Hiproom 59.7 "
Front Shoulder Room 64.7 "
Rear Shoulder Room 64.8 "
Interior Cargo Volume 66.9 cu.ft.
Interior Cargo Volume w/Seats Folded 118.2 cu.ft.
so i just need to measure how many inches is my current tire/rims size
SunlitComet
OBS Jedi-Do Good
And as bowtie mentioned maybe weigh the new vs old to at least know if braking issues might come up. At least you can trailer being prepared for changes to your driving habits if needed or adding a trailer brake system even for something small.
noJeepshere
Bountyfull, Utahrd
Find out from the wheel manufacturers website or by phone what the rated weight carrying capacity of the wheel is. I don't know for sure, but I doubt you can find an E-rated 10-ply tire to wrap around said wheel.
retorq
Kingman AZ
I would double check the tires max rating, lots of guys that go and put on bigger tires and rims get tires that aren't rated as high ... just a thought.
longstand
longstand
WOW retorq, thanks dude. i Total forgot about max rating. jezz. imaging the tire blowing up, and waste my $200 per tire, not including damage to my rims
longstand
longstand
I just got the SUV back today and i measure my outer part of the tire,
The total diameter is 32"
I been searching for total diameter of stock rims and tire, but i have no LUCK.
is anyone here has a stock rims and stock tire size in there possession? or know the stock diameter?
if you have it can you please measure it from END to END from the tire.. plsss
the only think i have found is this
~~~~~~ TIRES: P265/70R16: LF=4/32", LR = 2/32", RF = 5/32", RR - 2/32" ~~~~~~
I have no idea what is LF=4/32"
but i notice they are all 32". maybe thats a total diameter of the stock rims and tire
BrancoRST
