sealandsky
Yessir!Thanks for the response. What do you mean you keep in tow or manual mode? Your constantly toggling the little gear up/ down button on the gear lever?
Correct - the TCM is always trying to achieve about 1,500 RPM and that's the one place the Callaway tuning isn't great. At low RPM's the Supercharger tends to buck and surge as it tteeters on the edge of boost. By keeping the RPM's anywhere over 2,000 (about 2,500 is best) the system is smooth as butter, power is always on-tap and the exhaust sounds great. Tow/Haul delivers so/so results and I use that when I'm lazy. I also understand that tow/haul changes the suspension calibrations to a firmer level so have that added benefit. I would kill for paddle shifters! Please expand on the BBP?im guessing he is messing w/ tow/haul mode b/c callaway didnt tune the trans. (TCM)
so its much firmer up & down shifts, which is fun
its pretty bland shifting regularly.
as i had mentioned above ... BBP tuning took care of that for me
Call me cheap but I thought 10k was a little much ($9890.00 installed) I went with the GM big brakes for 2k installed, and why I am SURE the Callaway setup would stop my truck faster, I'm pretty happy with the GM big brakesCallaway offers a BBK (15" 6 pot, all 4 corners) & the dealer can typically install it, if you dont order it from callaway.
From what I can see from online sources, the TCM for the 10 speed transmission is still a bit of an issue for reprogramming.BBP = blackbearperformance.com
i provided driving logs to Justin & he took care of ECM &TCM...driving is so much more fun
no issues w/ taking it to dealer. i just reflash, if they add something.
however the dealer is told by callaway to minimize any updates during service.
& yes, paddle shift would be awesome!
Yeah, for a "daily driver" I didn't see the value in the Callaway brakes and went with the GM upgrade on the fronts. They are far better than stock and reasonably priced.Call me cheap but I thought 10k was a little much ($9890.00 installed) I went with the GM big brakes for 2k installed, and why I am SURE the Callaway setup would stop my truck faster, I'm pretty happy with the GM big brakes
I have a 2019 Yukon Denali / Callaway and have put about 6,500 miles on it since new. Thus far the only issues with the vehicle are GM electrical (passive locks, center tail light). The Callaway system has been rock solid and is fun to drive. The installation is as "factory" as it can be - very professional and flawless. My only complaint is that Callaway doesn't provide their own "owners manual" so I guess some things you just have to figure out for yourself. Rule #1: Always drive in either tow/haul mode, or manual mode. Driveability is much improved this way. I've adjusted to driving in manual mode 95% of the time.
