Cam Motion Stage 2 cam for 6.2?
Geotrash
Geotrash
Dave
Richmond, VA
I just thought to look for an emailed receipt.
28-12713265-16 - GM High Performance LS .550"
Lift Springs, Set of 16
So I'd have to go with the low lift if I'm not confused. It sounds like I'd still get a large bump in low end torque vs the LS9 cam I put in.
Right on both counts. Or, since changing out the valve springs is a pretty easy job, you could also look at the BTR springs because they’re good to .560
PatDTN
I'll watch your results with the high lift version before I decide. :cool:
Geotrash
Geotrash
Dave
Richmond, VA
I’m betting that the performance will be very close to the BTR stage 2 truck cam, with the exception that it will idle more smoothly. If so, I think I will be very happy with the performance. I’ll definitely post up the results in few weeks once the cam is in!
Josejr00
