Can’t shut wipers off!
hagar
Hey! Thanks for the reply! I think it’s also the BCM! Few weeks ago I had my engine light on and I had BCM code in the OBD reader. The codes went away since then but for the past two years when I bought this car I’ve had random mirror foldings and sometimes my door handle locks wouldn’t work and my interior illumination lights will go on and off when the car is off and locked. My rear AC also randomly turns on and off for no reason! I’m pretty sure it’s the BCM as I changed the wiper motor and the switch. The only time the wiper will shut off normally is if I re plug all the relays in the frontal fuse box! Even unplugging the battery wouldn’t work !!
Without a doubt is. I had one customer that as soon as you hooked up the battery with no key in, the wipers would go on and the horn would stay on. They do some weird stuff! New module and a flash, and it was good as new.
C
Chow567
C
Chow567
It was raining today, I think I found a way to not let the wipers go crazy. Basically switch between LO and off, no intermittent option. Let’s see if it works, if it doesn’t I will request a new module from the dealer
shootir
