can anyone honestly
gtbigup01
Columbus, GA
Say the have rear LED's that work like they're supposed to. That is running lights work and fast blinking wasn't a problem without you figuring out you needed a load resistor? If so what brand and where did you buy, oh this is for an 06 Denali or similar vehicle. Thanks
Tahoe03mm
Puyallup, WA
my lights all worked fine with the ones i got.. They came with load resistors only on the turn signals though. This caused a problem with the cruise control not working because it uses the brake circuit for the cruise "cut-off". I wound up wiring inline with it 2 load equalizers. one on each tail light.
gtbigup01
gtbigup01
Columbus, GA
Ok thanks for ur input
BlizzardX23
Sacramento, California
gtbigup, It really depends on the brand/light you purchase. A lot of new LED tails have everything built in so that your mentioned problems above are no longer an issue. Let me know if you'd like more info on these tails.... several of us have them
NJ04HOE
Paterson, NJ
I haven't had a problem with mine...I don't remember the brand name but I bought them from another member here,no issues at all.
gtbigup01
gtbigup01
Columbus, GA
Yes Blizzarxd23 send me any info you have on one that works pls since I already purchased a set off ebay got them in yesterday and sent them back today for poor fitment and fast blinking plus the running lights won't even come on. Hook up instructions were pretty simple matching the wire colors so I sent them back and looking at some Recon now, but for $299 I'm open to other brands. Thanks
BlizzardX23
^^ see, they are allllll the same light....just sold by more then one authorized dealer :)
Those are the same exact lights I have too, only..I got mine from Zomk Speed
Coop2015
