Can I change the battery on 2021 Tahoe?
N9Phil
I changed the battery in my 2020 Yukon XL Denali last summer and a few months ago i connect my XTOOL D8 scanner and I found a "Reset Battery" tab. I would assume that this might be so you can receive a warning when your batter doesn't charge right or can not hold a charge etc. I drove the vehicle for probably 8 months after changing the battery before resetting the reset with out aby problems so do a google search for "what is the purpose of resetting the battery after changing a car battery?" This will give you all the info you need to know. Good luck and have fun.
MannyvOBS96
