what I usually do is drain it, fill it with water, run it for a little bit, drain it, fill it with water again, run, drain again, usually after the second time around it is looking like mostly just water. then throw some chemical cleaner in there and run for 10 minutes, drain/run a couple more times then add fresh coolant. a little tedious but good for California cars
