Can only put in 5 gallons
W
wavejumper
Doesn't the line go to the EVAP canister not the gas tank?
Idk I will have to put it on the lift and see
galaxy S3
---------- Post added at 11:37 PM ---------- Previous post was at 11:36 PM ----------
What you're describing sounds like the fuel shut-off valve is stuck in the closed position. Used to see that problem all the time at my last shop primarily on Hyundais. Some older GM's and Fords have the same issue to, but more prevalent on newer foreign cars. If thats the case, the shut off valve is at the bottom of the fuel filler tube inside the tank.
So that closes once the tank is full?
galaxy S3
W
wavejumper
I just pulled the fill hose off the tank after I could only put two gallons in. I pulled it,off and 2-3 gallons came flying out of the tank. I can only assume its full now
Sent from my iPad using Tapatalk HD
tdeaton3
