Nicolai8775
- Joined
- Sep 15, 2016
- Posts
- 118
- Reaction score
- 64
Hey all, after blowing up my transfer case due to pump rub and subsequently running dry.. I realized while I was under the truck that I have dual fuel tanks.
My truck is a 2001 Chevy Suburban 2500 6.0.
Can anyone explain how it works, the capacity of the main tank vs smaller tank, etc. I assume when I fill up gas it fills up the smaller tank then trickles to the larger tank. Is there a pump in the smaller tank? I was chasing a P0300, where I did a fuel leak down test and noticed it dropped about 20psi after 45 minutes. Over night it would drop to zero. I believe I have fixed that issue but don't want to leave anything to chance. Is there one of those check valves in the auxiliary tank pump? Does it even have a pump?
