Can the Suspension control module cause yukon not to start?
jimmy1wheel
N.E. Ohio
My Yukon would not start the other day, so I had it towed to the dealer. I had power, lights, everything, it just would not crank or even click when I turned the key or tried the remote start. The dealer called me and said the starter was bad and they were replacing it under warranty. An hr or so later, I get a call back and they said something else is still not letting it start. The next day they called and said it was a module that was under the rear spare tire that wasn't letting it start, so they replaced it and I was charged $712.00. I looked at the bill, and the module is listed as a "suspension control module". My question is, what does this module have to do with starting? They specifically told me it would not start if this module was bad.
BanditHoe
Yes, mine did it. Unplug it and live with the light or buy a new one online for about $350. The BCM communicates with all the modules, if one module goes down the system goes down - sometimes. There are upwards of 7 modules (depending on options). In another thread I explained it better. Common failures are suspension module (called the vehicle dynamics control module), radio, airbag and fuel pump control module. The downside is, it's a VIN burn unit and you need the dealer to burn a VIN into it, might work work without it too, not 100% sure.
jimmy1wheel
jimmy1wheel
N.E. Ohio
Thanks! They told me there are 24 modules on it and it took them forever to figure it out. At least they chalked the diagnostic charges up to a learning experience and didn't charge me.
BanditHoe
Ya, I can imagine. I knew specifically which ones normally fail in my climate and started there.
I'm sure if you start counting all the smaller modules too (e.g., windows, etc.) there probably are 24. What a pain.
Camaro71
I just had this happen today & yes it does cause a no crank/ start issue. 08 yukon denali. It stopped my rear power lift gate to quit & oil temp & gas guage to quit. I unplugged the modual & the problem stopped . Now to order a new modual. What a pain trying to track down tha culprit.
SUV-2007
I unplugged it, engine did turn over and attempted to test drive but it began to malfunction. Is this normal and how can I tell it actually is the Electronic Suspension Control Module?
petethepug
Michael
SoCal
Nice little tidbit bit of info for those of us with z55/z95 suspension. The module is conveniently located under the spare tire :disgust:
j91z28d1
I thought there was more to it than just unplugging it. you needed to bypass it by jumper the can bus wires, so the network is back working?
Levi0320
So that’s what fixed the issue? I have a 07 Denali same issues. The gauges are also acting up and it was stuck in second gear and my scanner would not communicate with any of the ECMBCMTCM and I’ve been trying to track it down for weeks, so which module was it for you?
Epicshift23
