Can't get brake lights or backup lights to work?
craigcriv
Brake Lights and Backup Lights don't work?
Just purchased a 2005 Tahoe and realized the brake lights and backup lights do not work. The 3rd, top, brake light does not work either. The tail lights and turn signals work fine as well as the flashers flashing the turn signals.
Checked all fuses and bulbs and are ok.
There is power to the orange wire on brake switch and the white wire on the switch lights my tester when I depress the pedal.
Any suggestions?
Craig
chauncey0337
MLT, WA
Can you test to see if you get power at the brake light bulbs when you press the brake and at reverse bulb when in reverse?
C
craigcriv
Yes checked all.
---------- Post added at 11:20 AM ---------- Previous post was at 11:14 AM ----------
Could it be the brake switch? Would a bad brake switch cause the backup lamps to not work?
But the white wire on the switch does light up on the tester when the pedal is depressed.
chauncey0337
MLT, WA
Do you have the correct dual filament bulbs in the bulb sockets? I believe they're 3157.
C
craigcriv
Yes have correct bulbs. But seems I am not getting power to the bulbs.
I'm now going to check the plug in sockets above the tailpipe.
chauncey0337
MLT, WA
Yeah I would check all the connections. Must be a break in the line somewhere.
C
craigcriv
There is no power to the brake or backup lights at the junction above the tailpipe.
chauncey0337
MLT, WA
Hope I'm not beating a dead horse but sometimes a bad fuse can look like it's good.
tony97218
