Can't lock radiator fan to unscrew
Daviddto
Houston
I am trying to remove the radiator fan and when I put the wrench on it it just spins. The belt is still on and tight. Can anyone advise me as to what to do?
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Put wrench on the fan clutch nut and whack it with a hammer hard and quick with a hammer in a counter-clockwise direction. Looking at it from the front of the vehicle facing the rear is where i am referencing. It may need a few whacks till break it loose. Once you see the nut spinning freely, spin the fan by hand to get it off the water-pump pulley.
A trick is to have a helper put tension on the belt tensioner while you do this.
Soaking the fan clutch nut in PB Blaster doesn't hurt either.
I always use my pneumatic hammer to do this so it's easy but I remember the DIY days.
Gzes
the drifting 2dr
Wichita tx
Pretty easy to do. Since you've got a wrench put it on and whack it with a heavy hammer
pnwdan
Cunning linguist
Arlington, WA
I just went through this yesterday. After an hour of fighting it, I put a chain wrench on the pulley and ended up using a wrench on the nut with a 2 foot breaker bar. Definitely not ideal but i got it done. Try a strap wrench first. use anti seize on the threads when you reinstall too
Daviddto
Daviddto
Houston
Thank you all for the good advice. I worked around the fan. It was a pain in the butt but I got the power steering pump changed out and the whine is gone.
pnwdan
Cunning linguist
Arlington, WA
Glad you were able to. That is exactly what I was changing out yesterday
Sent from my SM-G900V using Tapatalk
ezdaar
Chat Troll
Redneck central, Aka Houston
guys, use a long bar to get the torque required to bust it loose.
I use a big crescent wrench and a piece of fence pipe 4' long.
put a pillow on the fender to stop damage.
Then simply whack the pipe with a sledge hammer. it instantly pops loose.
afpj
What's your secret to keeping the fan pulley from turning while you're wacking on the nut?
trav02nj
