cat questions
ktmhans
Connecticut
Ok so, it looks like i.have a cat problem. I called magnaflow and the only one they say will fit is the 51019. There like $149 each. Then i have to weld them in. Rockauto has cats that come on like a factory y pipe that bolts right up to manifolds and muffler secton. But i dont see any specs on pipe gauge or diameter.
Does any one have any experience with these.
WildBill
no expierence with either. But, I would bet the Rockauto set up is small diameter, wrinkle bent tubing that is basically a stock replacement. I would see if i could upgrade and buy a good large diameter mandrel bent y pipe with cats already in it. Magnaflo may offer something? good luck.
Mrsharza
