Center cap not fitting new wheels - lug nuts too long?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
No. The threads are for the plastic black covers that thread on to the outside of the lug nut. You can use these too. Don't worry about the plastic covers since your center caps will cover them.
Fless
Super Moderator
Elev 5,280
^^^ What @PNW VietVet said. The earlier stock caps had plastic nuts that screwed onto the outside threads of the lug nut, like the pic below. Your caps probably have some kind of spring clip to capture.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
They can also be individual caps like these that thread over the lug nut and then the stock wheel will have a smaller center cap that does not cover the lug nuts. The pic that @Fless posted is a design that IMO is a PITA to work with. I dealt with these on my vehicles and in my shops and more than once came close to throwing them against the wall.
C
Chooch
First of all, this forum is awesome! I got my hands on some OEM lug nuts that should fit. The guy who sold me the wheels had them spare.
Second, I do have a question...
As the caps are off, I am taking a look. My rear wheels don't have a center bolt and the front do. What is that?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
The front is the threaded stub of the outer cv joint that is sticking thru the front hub bearing and the nut is there to hold it all tight. There is a shaft and an inner cv joint that splines into the front differential gears. That means you have 4wd. At the rear you are seeing the center cap area of the rear axle flange and there is no cv joint there but the other end of the axle is splined inside the rear gears.
C
Chooch
Thanks! So you're saying my wheels aren't going to fly off? :)
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Nope! You’re good!
That being said, this is the first time I remember a guy posting a problem here and found out the cause was their nuts were too big!:eek:
Yea, it's a curse.
Not unless you drive it like you stole it and do "Dukes of Hazard" jumps with it.
petethepug
Michael
SoCal
Congrats on the 20’s and resolving the lug issue. They 20’s set the truck off. Keep an eye on your tire pressure for the first few months. The majority of the rims pulled from originally equipped vehicles are susceptible to the chrome clad peeling at the bead and the cause of slow leaks.
A good deal on OE 20’s may be a telltale sign, hopefully not. Now you can recoup your costs and sell the other set of rims.
Stevemo70
