ceramic coating headers?
Jay
It'll be a mildly noticeable difference in heat under there. Don't do it thinking you'll gain any real power.
It helps non-forced inducted engines by keeping more heat in the exhaust which leads to faster exhaust velocity. Again, not a "big" difference. It's mostly noticeable in high-effort builds (i.e.- 500hp+ naturally aspirated small blocks may gain another 10hp or so with coated vs non-coated headers).
Where ceramic coating (outside and inside) really helps is in turbocharged vehicles since their pre-turbine exhaust temps are much higher... not only from the heat of combustion (1300+ EGTs), but also drive pressure. Generally speaking a turbo ideal for 20psi of boost on a stock-ish 5.3 can have 20-40psi drive pressure, which adds considerable heat and makes the headers glow red hot. The coating lets you perform at high boost for longer periods, lessening the chance of a blow-out.
If the extra cost isn't a concern to you, then go for it. If anything, it'll lengthen the life of the headers and gaskets by buffering thermal shock.
blueflamed03
Oklahoma
correct, I always coated all my headers HPC inside and out, no only for temps, but they look better than painted, which comes off, and they last longer.
But if the LPP's are stainless, and you run 205-210 anyway under the hood, the stainless is fine.
tony97218
