I went from stock 17s on my 08 to 22s to 24s and had no issues with 4wd.
So i will buy 2 new tires with same tread on 20s n put back n check if it works fine .looks like the tire hieght on rear wheels 20 was little high then front i will be matching with front samd tread n height .anything else iam suppose to do after changes.
Because all 4 tires were same size....OP had diff size tiresI went from stock 17s on my 08 to 22s to 24s and had no issues with 4wd.
But problem was, so op knows, and in my opinion, was the diff tires/heights on the 20's.
I think it was non use for a year....I'm still struggling with that little bit of tread difference causing a problem...idk
