Cheap sway bar links for rear 5" drop
M
Max
Mile High
Denver
Still suspension related so I don't see the issue. The lower coils are an option even if I don't notch it I can run 10psi in the bags and still sit 1/2" lower or so. I think it would handle better with smaller coils, helper bags aired up, and the sway bar angle corrected. I have it pretty dieled in right now it will walk the ass out perfect under throttle around corners w/o oversteering too much, still too sloppy even for an suv tho.
M
Max
Mile High
Denver
New magnacharger kit with the twin screw eaton TVS-1900.
M
Max
Mile High
Denver
So much for that notion, little bastards are just a hair too short and hit my panhard bracket even it I notch the damn thing. I guess 1" off the stockers is the best bet so next step is welding the ones I cut and trying again. I had hoped it would be easier lol.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Even moved to the passenger side?
If you can, send me a pair please...
:Handshake:
M
Max
Mile High
Denver
I tried everything. They may have fit with the stocker but not with this big ass eibach. I'll get some of the welded links on and let you know, you're gonna owe me a case of beer and some nuggets with all the shit I keep sending you lol.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
done
:Handshake:
Modded
That Guy
Max how much thicker is your Eibach rear bar?
Thinking about getting one of its worth it.....
M
Max
Mile High
Denver
Never measured the stocker but it's significantly larger and quite a bit stiffer. Made a huge difference.
chistoso
Arizona
That's what she said..:Handshake:
I tried cutting my stockers and tried to weld the back together and they kept breaking at the welds. Even tried to sleeve 'em amd weld the sleeves but they kept snapping. I think I know why, You say yours hit the panhard bar and I thing mine did as wellcausing them to break with the pressure.. I just went back with a stock set..
SPIS
