Check engin light
jdawg901
memphis tn.
After i replaced the fuel pump the cel came on stayed on for a while .well the other day i was just doin some minor maintanance i noticed the coolant temp sensor broke so i replaced it the cel went off for a while untile the truck made to operating temp and came back it does this everytime i start the truck .could it maybe be the o2 sensors.i bought the truck for 1000$ it was a work truck but need with a wife and child i was into the imports but always wanted a 2 door tahoe now thats all i drive and luv it .oh it has 300,000 miles but still runs good .i have a nunerous things on the list that i want to do to the truck but first thangs first .
TahoeGoBoom
blue interior guy
I'd say go get the codes read. thats why they're there, easier than guessing what it *could* be.
ravingmadman
Chief Knuckle Buster
Greater Seattle
Spend $60 on a code reader. Absolutely the best tool for cost I've purchased. Just get the cheap one from O'Reilly's. It is blue, and does everything you need.
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
just go to oreillys, autozone, advanced and they will scan in for free...then come back and give us the code and we'll see if we can then help.
Pat
haks310
Got LEDs?
SoCal
No need for a code reader just use a paper clip. Jumper pins A and B, the two top right ones. Stick the key in the ignition and turn it forward but do not start the 'Hoe. The engine light light will flash in different sequences telling you what codes you have in the ECM.
Here you go:
http://www.troublecodes.net/GM/
TahoeGoBoom
blue interior guy
first we should prolly figure out the year before we tell him how to check it. lol
hosleyb
