So I keep throwing a check engine light (95 hoe) getting a code 34 or 36, says EGR valve. Replaced with aftermarket. Still getting code sporadically.
Question is if you are not using AC Delco EGR, are you prone to throw a code for some reason? Seams like I read if you are not using factory parts for that kind if stuff you will keep getting the same code.
Anyone experience this? Thx
