Check engine oil level message 02 Tahoe
02ncHoe
My check engine oil level message came on in my 02 Tahoe with 131,800 miles tonight. After letting the engine cool the dipstick reads add. I'm 3800 miles into my oil change. Going to have my oil changed tomorrow since my change engine oil message hasn't come on yet. I usually go 5k between changes. My first question is should I stick to every 3000 miles or wait for the computer to calculate the change? Second, is it safe to assume that the engine is using a quart of oil between changes which is in specs with GM? According to my research the difference between add and full on the dipstick is one quart. Does anyone else's burn oil between changes and if so how much?
gitrduun
It never hurts to change your oil. Hell, you could do it every day if you wanted I got the same thing with my old sierra but it only happened once, so I just put oil in, so I think these engines do consume a bit, im not sure how much is realistic though.
04SS99Denali
NY
how much oil did you loose? and i go by 5000 the computer usually tells me to change it right around then anyway
02ncHoe
02ncHoe
I'm not real sure. The dipstick reads add after the light came on. I've been told that means its a quart low. I think I'll add a quart and see what it reads after and let it go until the computer tells me it's time for an oil change. Definitely going to monitor from now on.
Rivieraracing
Yeah, if my light comes on that usually means I'm a quart low on oil as well!! I burn some oil in my truck, but about the time I need to add some, shortly after the light comes on to change it!!
afpj
you may want to try one the high mileage motor oils if you aren't already doing so. Most use Valvoline Maxlife based on what i've read on this forum, but other brands are also mentioned in threads. Has it burned this much oil in the past?
Vinniety
Westchester, New York
If you want top it off and wait till the oil needs to be changed. I dont see anything wrong with what your doing. At least your not low 3-4 quarts and after you top it off feel that its good enough and consider it an oil change, hahah. Some people do.
Are you using synthetic oil? I know synthetic is thinner and will burn quicker or slip through gaskets more easier.
02ncHoe
02ncHoe
I've only owned the truck 4 months. This is my first oil change cycle so not much to go by. My mechanic suggested an oil change with high mileage oil and pcv valve replacement. Will monitor the next cycle closer and hope this remedies the problem.
afpj
if you're replacing the PCV valve, go with the updated one with a smaller orifice and no moveable valve inside....there's a thread about that on this forum somewhere, but the mechanic should know. It was updated specifically for the oil consumption problem.
Bedore
My engine has been consuming oil as well, and I have seen that message many times. It's a 2001 Tahoe 5.3. When I first got the truck over a year ago, it wasn't bad but lately it's been consuming a quart every 1500-2000 miles or so. I am going to change the PCV valve and hope that takes care of the excessive consumption. I have never had a vehicle that uses oil like this truck.
chevius
