Checking the o2 sensors
sparg93
Expedition Tahoe
NJ
that's awesome - do you have a link to the scanner???
sparg93
Expedition Tahoe
NJ
that is too cool - do you know if it will work w/my OBS '99 Tahoe?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
O2 1x1 and 1x2 (assuming to be bank 1 pre and post)are lagging behind in activity do both those sensors first and retest. If they turn out to be accurate then it would indicate something wrong with that bank. If you see alot more activity when you replace them and it is more significant then then the other then you would benefit from doing bank 2 as well.
destroyer1362
destroyer1362
A work in progress
Midlothian, TX
Yeah, it will work. Any car/truck w/ an OBDII port.
---------- Post added at 04:40 PM ---------- Previous post was at 04:37 PM ----------
Thanks man, I hope this works, would you assume 1x1 would be driver side?
SunlitComet
OBS Jedi-Do Good
drivers is bank 1 so yes 1x*should be bank 1 and 2x* should be 2 or right side or passi side. 1x1 would be bank 1 pre converter and 1x2 would be bank 1 post conveter. Noticed you in the snow if that happens alot the thermo shock from the really cold to a instant heated sensor could be taking its toll on them and breaking down the elements.
destroyer1362
destroyer1362
A work in progress
Midlothian, TX
sparg93
Expedition Tahoe
NJ
yeah, I'm hooking this thing up to my laptop...i'm in the dyno age with my phone :)
BKraft
