Clicking/Tapping Noise coming from 3rd row area.
08grey
Try to narrow it down. Run the rear ac and see if you hear it. Then without. Maybe it's a blend door.
Maybe and just maybe you have kids like mine that think everything that has a opening is meant to take change and there is a nickel in there.
Labman2012
I had this same issue and after about 3 months I found it. The headliner has little foam spacing blocks in it that have double sides tape on them. Once they wear out they will click or tap because they are not sticky enough. Here is the solution!
Take out the 3rd row light
Look at the back and locate an area where you can run a self taping screw through that will hit the bracket behind it but not hit the metal strips that carry the power
This may seem a little crazy but believe me I tried many things and this was the only thing that worked.
I just tried to upload two pictures to show where the screw goes but in will not let me. I will upload them when possible.
Just remember to use a self taper that isn't too long and make sure it has a large flat head so that it doesn't eventually pull through, also don't tighten it all the way down, just enough to where the headliner is snug.
Hopefully this is all clear, been writing this while I'm busy at work.
Y
Yukon Jon
Middleburg, FL
Seems like I found it. The back rail of the roof rack that slides wasn't locked all the way. I have it on correctly but theres still some movement to it. Theres still some noise but for the most part its gone. Thanks for all the help.
Labman2012
etreanor
