Clogged Trans Filter, is it toast?
jyi786
Yes.
Your old radiator's ATF side tank has mung and detritus and other stuff in it that you
DO NOT WANT
mixing into your new ATF / transmission.
Since it is impossible to clean that stuff out of the radiator's ATF side tank, either don't use it, or replace it with a clean radiator.
Genuinely curious, what do you mean by ATF side tank?
Here is the radiator in mine. It has the transmission cooler integrated.
Marky Dissod
The radiator part of the radiator is for antifreeze.
The motor oil side tank is typically the left / driver side one.
The Auto Trans Fluid side tank is typically the right passenger side one.
I will not call them coolers.
For motor oil or ATF to be COOLER than the antifreeze, requires separate EXTERNAL coolers.
NickTransmissions
Sin City
The transmission bench
The transmission was $10k. I don't have another $1k just lying around to further spend on this entire ordeal. I did ask them to flow test the current radiator and cooler lines to ensure no blockage.
If I have to shell out another $1k to protect my $10k investment, I'll have to figure it out, but I thought flow testing and flushing the current one was fine.
At 120k or so, its probably fine for now/short term but I'd prioritize its replacement within the next 30k or so. The main concern is the internal trans cooler leaking coolant under pressure into the trans. Just one drive cycle of this is sufficient to turn your new 10k trans/tc into a fancy, heavy transmission-shaped paper weight.
Like i always tell folks: cost+risk must be less than benefit.
If the benefit of radiator replacent in terms of cost avoidance (replacing trans again) combined with relative likelihood of failure in relevant timescales is less than the $1000 (cost) you'd have to spend to mitigate the risk of failure (which you deem to be low at this time), then wait.
If the spending the 1k to replace is more beneficial to you than the risk you're taking by not replacing it and having that risk realized when it fails, then invest the 1k to replace it now.
Ultimately, it's your call...
jyi786
Do you advise changing the transmission cooler lines or can those be reused?
XSoph
