Clunk....but in the rear
cmc76
So I've got a clunk and took care of the usual culprits first. U joints. Greased the yoke.
But I can feel and hear a clunk switching from D to R. Also sometimes during light acceleration.
About 185k , I don't tow. But who knows past owners.
Does slop in the rear end require a rebuild. Or start looking for a donor?
drowssap
Colorado
Pinion bearing in the rear? Pinion nut loose? I have had the exact same symptoms on chevy rears and this was the problem on two of them.
rockola1971
Indiana (formerly IL)
You got probs if your rear pinion nut is loose considering how much its torqued when installed properly. Done incorrectly OR sabotage.
cmc76
cmc76
A minor hum. Not full time. Doesn't change with speed.
mechanic0
