Clunk Going Into Gear - UJoint?
JPVortex
Connecticut
Hey y'all 2002 Suburban 1500 5.3, 4L60e with a 10 bolt rear. Noticed this clunk, particularly when shifting into reverse. Can hear it sometimes in drive as well. Sounds to me like it's coming more from the rear. Hard to pinpoint the source of the sound. Not sure if it's a ujoint that's starting to show its age, the trans mount, the trans itself, or the rear end. Don't notice anything weird when driving.
Sorry for the annoying exhaust sounds and the lifter tick, really noticeable from under here lol.
I have videos here:
Rear end(2 videos):
Front end:
Thanks y'all!
JPVortex
JPVortex
Connecticut
Honestly to me this sounds like a bad ujoint, and they’re all the original nylon injection ujoints. I think I may just go ahead and order 4, then replace all of them on the truck.
May go with moog, seems like the moog ujoints actually have better reviews than the gm genuine ones.
strutaeng
Dallas, Texas
Seems kinda normal to me TBH. Unless the video isn't picking up the real sound?
You could simply remove the driveshafts and move the u joints to see if they are still or seized. But replacement is not a bad idea because they do wear out, especially if you live in the rustbelt regions.
JPVortex
JPVortex
Connecticut
Ok it does? I’ve never heard a vehicle straight up clunk going into gear, sounds like a metal clunk. Might need headphones to hear it. I was on flat ground too not a hill.
rockola1971
Indiana (formerly IL)
Looking at the video showing the rear ujoint at diff while the video is enlarged I can see the pinion jump during the clunk, not the ujoint end of it either. I suspect your clunk is in your rear diff. Id pull the cover off and have someone move driveshaft back and forth just slightly and see whats going on in that diff. Likely wear and tear on the gears. You should be able to see the wear on the teeth. Dont forget to block the wheel(s). I did not see any play in the ujoint, but it being original it will likely need to be replaced at its age.
You can always just replace the ujoints since they need it anyway and then see if you luck out and thats all it needed BUT I would pray before and if it turns out to be just Ujoints, go buy a lottery ticket.
JPVortex
JPVortex
Connecticut
Kind of seems like it right? Seems like the pinion is “jerking” a bit. Should the pinion stay completely still while shifting into gear? I was firmly on the brakes during the video, so I’d think it shouldn’t jerk like that. No weird noises driving or anything, it’s strange, really is.
Davoe1975
