- Joined
- Aug 2, 2018
- Posts
- 8,107
- Reaction score
- 11,249
There are a number of possibilities regarding the source of your noise. I recommend that you go to a trusted local repair shop and get it up on a lift with someone inside the truck. Then go through the actions that generate the noise, and a mechanic will look around underneath the truck, with a stethoscope if necessary, and identify the source of the noise. Otherwise, you are just firing the parts cannon, hoping for a solution.Honestly to me this sounds like a bad ujoint, and they’re all the original nylon injection ujoints. I think I may just go ahead and order 4, then replace all of them on the truck.
May go with moog, seems like the moog ujoints actually have better reviews than the gm genuine ones.
In my case, my front differential mounts were worn out, and as soon as they were replaced, the noise was gone.
