Clunk on hard acceleration
broken08
105k on Yukon XL Denali. When I hit the gas even mildly hard there is not really a noise but a feeling of nothing, nothing, nothing WHACK. Like a delay after I hit the gas then a hard catch.
I'm fearing motor mounts, or maybe something worse?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
motor mounts are a common problem.
justinesky
Motor mount. just changed mine yesterday. took about an hour 30
DRG
I just changed engine mounts and the clunk went away. Right side is more difficult. Manual says to remove exhaust manifold and disconnect coolant hoses. I did not do that. I did remove exhaust manifold heat shield and AC compressor + compressor bracket for better access. I found the most difficult part was getting the bolts started into the engine block.
redman1
