clunk when traveling over bumps or releasing brake from complete stop
RdHawg
Had a similar issue while offroading once - turns out my lugnuts were loose. The motor torque would cause the wheels to slip and elongated slots in the bolt holes. If this is your case - you might not want to wait till parts fall off.....
ATIII
Brighton, CO (Denver)
I got the same type of noise going. Kind of a pop clank sound. Usually does it when I go forward in the morning after backing into my driveway every night. And sometimes I hear it rolling at slow speeds in a parking lot on bumps. Seems to be the rear somewhere as I can kinda "feel-hear" if that makes sense, where it's coming from.
OhioHoe
Southern Ohio
Mine has the same problem occasionally. I've checked several times but still can't pinpoint the source
knometh
