Clunks into gear
Narco
Atlanta
mine is doing it also. ill also heary it every now and then if im stopped at a light and when i hit the gas to take off it'll clunk. still the u joints?
no one ever did say what it is they do
ecordell
CordellDesigns.com
Merica
The u-joint connects your drive shaft (at each end) to your yokes, one at the front of the rearend housing and one at the tailshaft of your transmission.........
Narco
Atlanta
would mine still be u joints if it clunks once im already in drive (launching from a stop, etc)?
DREADMAN109
Know this is old but I thought I should let everyone know. If you hear your truck start to make that dreaded clunking noise get under there and check it out. I got under my truck and dropped the drive shaft and all the bearings on one of the yokes on the front one was completely gone and was beating against the inside of the shaft. It had manage to wear to grooves into it and I thought I was going to have to replace it. Didn't though :worship:Once I got the new U-joints in, it fixed everything, the clunking, the vibration I was getting at 75 and this squeaking noise I was getting on occasion.
tybardy
everyone needs a Hoe
Gilbert Arizona
yo blue.... you said something about a press? I need to get this done in my truck and I suppose I never gave any though as to what tools are needed? Anything special, I have all the standard issue tools
PartsTester3000
