Cluster Not Working
Good news, it works now. I plugged in the old cluster, which worked, I then replugged in the Escalade cluster, and I heard the motors whirring, a8it works now. Must've been something loose. I'm not gonna complain. Hopefully it'll stay working.
M1Gunner
Gainesville, Fl
Old cluster.View attachment 185524
Escalade Cluster.View attachment 185525
Ha! IT’S ALIIIIVE!!!! That’s awesome, hopefully it stays all good brother!
ScottyBoy
Shreveport, La
C'mon Red, remember, it had the 4.8 in it.
Im hoping. Machines are a strange animal. Thx @M1Gunner for the help. You too @ScottyBoy.
It's very possible that it was something as simple as a loose connection or a bad connection. I've had some circuits act up before and they mysteriously started working just fine after unplugging the harness and plugging it back in, or pulling the fuse and putting the fuse back in.
Bonestock
Had this issue myself but with the stock cluster. I had to pull the fuses out and slide them back in and it worked. Turned out to be corrosion on the fuses. I replaced the fuses and hadn’t had a problem since. If it happens again like mine did about 10 Times may try replacing the fuses even though they’re good. Or swap back to a 4.8l. Either way
Never!!
Noel1971
