Cold air intake?
Bigpuddie
Thomasville, Pa
How is that a better solution? It's basically the same thing.. The eBay I take is like $50 for same results me that airid is gunna cost more.
I meant better than a full CAI. They don't improve performance at all...Factory box does a good job...
~the Captain
06_2WD_Z71
I recently had to fix a water leak, and decided to pull apart the factory intake to see if there were any weak points. I was pretty shocked at what I found. The whole thing is looks good with the exception of one area - the 2 small inlets to the airbox. First of all, the size of the 2 holes is questionable. And the bigger one up top is partially blocked by the side of the filter. But the worse thing was that there are 2 corresponding holes in the fenderwell, and they were not lined up with the airbox well at all!
I removed and reinstalled the air cleaner base, but the positioning was the same, the holes in the base of the airbox did not line up with the holes in the fenderwell, and the inlets were partially blocked. So with the base installed, I put a Sharpie through the airbox holes to mark on the fenderwell where I wanted to cut. Then I opened up the holes in the fenderwell a much as I could while still being able to keep them sealed to the inlets on the box. I'd guess I increased the area of those holes 50% or better. Then I went through the plastic airbox. I opened up the inlets on the lower half of the box with a die grinder as much as I could without the thing falling apart. On the upper, I noticed a lot of plastic flashing right by the MAF inlet, so I smoothed that out. I also ground on a few ribs on the upper near the MAF that I thought might be blocking flow.
The seal on one of the inlets was partially gone, so I used some A/C insulation to make a new outer seal.
Looking at the factory airbox, it is easy to see that if you really want lots of cold air, you can just cut out the bottom and optionally install a tube, which is what some of the aftermarket kits do. Forget the "Swiss Cheese" mod, that is a disaster for airflow. Yes more air will get in, but coming through several small drilled holes it will be "dirty air" (sailors and pilots will know what I am talking about).
I decided against opening up the bottom. It would probably be fine, but I recently got caught in the floods in Baton Rouge. And I decided that if I ever need to go through high water again, I want that extra margin of safety. It is hard to determine where the air comes in to the holes in the fenderwell. Shining a light into the holes was of little help. It is definitely a convoluted path, but in the interest of keeping water out, that is probably a good thing.
Without a doubt, the truck has a little more intake growl to it. It feels faster up top of course, but that is always the case when you are expecting it.
Also, I picked up 1-2 mpg. Ha ha, just kidding! I always laugh when I hear that with an EFI car, because at part throttle, the throttle is holding airflow back and the airbox is not even a factor.
If anyone is curious about this, just remove the top of the airbox and then remove the air filter. Then slide your hand through the inlets in the lower 1/2 of the airbox. If you hit metal, there's your answer.
I bought this one just after you posted it. Will be in Tuesday. $120 cdn with shipping. Exchange still sucks ! And customs charges suck !
But I get a new toy :chewie:
I will let you guys know what I think about it when I get it on.
Canadian, eh? Lol
#1taho
5150TAHO
niagara falls ont
Massivespl
Thanks for the link to this kit. I haven't installed it yet ,but I got it and it looks like a good kit.
Thanks man :cheers:
#1taho
5150TAHO
niagara falls ont
~the Captain
You need to look at the factory air tubes, they have three air damping areas that restrict the flow and the air box has a smaller inlet than the out let. Will any cold air intake add a lot of power NO. But will it improve flow? YES. We won't get 5 more hp but ther is defiantly a improve ment. That's why we are not spending big money on these kits. It's not worth it. But this cheep kit will do everything the kits three times the price does. I bet if you tried one you would like it. Happy motoring man :boti:
#1taho
5150TAHO
niagara falls ont
image.jpegNice & thick steelimage.jpeg Looks like it will seal up goodimage.jpeg More pics of the kit. I would have it on tonight but the wife took the keys !!!!
For what it is. I am extremely happy with it. May have to paint the tube black tho. It's the only Chrome on the whole truck !
08HoeCD
Yup.
Lots of vehicles respond well to aftermarket intakes and CAI kits, so it's the first thing that people ponder when they get into a Tahoe or Yukon and want to improve performance.
But the tiny gains you get with these kits versus the factory set-up = not worth the $$$.
black2002tahoe
