cookiemoonster
- Joined
- May 12, 2021
- Posts
- 7
- Reaction score
- 10
Hi all!
I'm hoping to find out if anyone has had issues with coolant leaking from around the water pump and thermostat housing.
I've looked it up and it's not seemingly a common issue but from what I've seen in regards to the thermostat housing using only an o-ring for sealing where the two faces meet, i imagine it could possibly be a common issue.
I have a 2004 Yukon and have experience in diagnosis and repair (took some courses years back and ran a freelance shop out of the garage in my previous house)
I have a coolant leak which isn't consistent and seems to only appear when the engine cools down (which makes me suspect it's an issue with some component shrinking when it cools and opening up a spot for the coolant to leak).
I just ordered one of those "cameras on a stick" because I couldn't see much with my mirror on a stick (side note, they're on sale right now and I'll link below; I get no commission for this, just want to share) and will be using it later today to try to find the leak.
I was hoping for some input on where i might focus my search. I do not believe it is a cracked block (would be a crazy crack to leak as much as a liter or two in one sitting) but I'm unsure of how to proceed as I've even added UV dye to try and find the source but all i get is the splatter from the belts flinging the coolant (from what little does actually leak while the engine is still hot).
Sorry for the huge post, lol. I hope I don't bore you all to death!
Best wishes!
p.s. here is the link to the camera on sale:
https://smile.amazon.com/dp/B07PBW52SF/ref=cm_sw_r_cp_apa_glt_fabc_VEECYXRY208D7SKEFGE1
Best wishes!
