Coolant leak Issues
Masonisking
Hey guys,
I purchased a 2012 tahoe about 8 months ago, and have had one of the worst car experiences from the lifters getting stuck, to a constant check engine light from the phazer sensor. The other day i was on my way home and in some traffic, and noticed my radiator fans kick on and could hear them inside. The temp on the gauge rose a little, but not anything i was worried about. I have been noticing them a little more, and today had it tell me the engine was hot (Not all the way to 260) which i stopped and it cooled down, luckily i was only about a mile from home.
Once i got home, i let it cool to check the coolant and realized it was nearly if not empty. So i went and purchased some more, filled it up. And was beginning to bleed the system, when i noticed all my coolant was now on the ground. So i shut the car off, the leak stoped. However, Im not sure where its coming from. It seems to be under the radiator on the passenger side. I cant see it from the top, and i recorded underneath and couldnt see anything either. I will attach the video shortly. What do you guys think could be the issue?
thanks!
Post your video to a host site like YouTube and share the link here; TYF can't host videos.
M
Masonisking
- Not sure why it uploaded shorts. Top of screen is the passenger side, where the leak seems to come from.
mikez71
Good time to throw in a new radiator and hoses. Definately seems like it's leaking up front!
j91z28d1
how many miles are on this thing? do you do any of your own mechanic work?
cause it's probably about time for a full cooling system rebuild. there's some plastic T's up at the firewall that usually fail first, but looks like yours is something else. but no matter. the T's will go soon anyways.
replace T's, factory oem only. there's some metal Dorman stuff, but it doesn't seem as clean of an install. radiator (denso only I believe) water pump, oem or millings and only a oem t stat. I personally don't trust Motorrad brand, and oem is the same price and all the hoses. all the part numbers and how to's are around here somewhere.
just do it all at once and be done with it.. I say this and people seem to not agree, but I've been around a lot of vehicles over the years and I've never been around a vehicle that has a timer like these.. it's crazy how common it is for parts to fail like clock work. you hit the age and or milage and ding, timer goes off.
as you search around and see when guys are changing things, start planning so that when yours hits that you're ready for it.
I did the full colling system right after I got mine, wanted to avoid the over heating since it's mainly the wife's daily. didnt need that hassle.
check you're motor. mounts, if you haven't done them they are probably bad and if you have the rear air bag/mag ride those shocks will be leaking soon.
At least you got the lifters out of the way early? try to get a new torque converter soon as you can afford to if only 100k.
solli5pack
Double check all your hoses but I'm guessing it's probably leaking from one of the seams on the Radiator..pretty common failure point. As stated in a previous post, never a bad idea to replace everything on a high mileage coolant system.
That's a large leak and shouldn't be that difficult to find. You might pull the fan assembly out to get a better view of the radiator and the connections.
petethepug
Michael
SoCal
The mystery leaks come from the high pressure areas where it instantly vaporizes and only leaves behind a powder residue.
Replace the coolant overflow reservoir as well as the radiator. The end tanks of the radiator and coolant reservoir tank only leak / mist away coolant when it’s almost ready to go into critical overheat and cause damage.
On our 08 YXL it broke in this order…
* Crack in coolant reservoir.
* Crack in radiator end tank.
* Broken heater hose T.
* Accessory belt tensioner fail.
All of the above can total a $7k engine in less than 10 minutes. Recommend using only the green Gates accessory belt kit and OEM coolant hose T’s. Order them early off Rock Auto because when you need them they’re usually not available locally unless a dealer conveniently has the tees for $100 ea.
M
Masonisking
Alright, I did a little more digging and iv found the issue. Ended up being a large crack in the plastic of the radiator on the driver side and was bring blown to the passenger side it looked like. It is now holding coolant, but i have the traction control and sabiltrak errors now, any ideas on fixing that?
