Definitely will do that right away.Is it located there at the under hood fuse box? Believe I seen it there.Correct me if wrong.Don't discount @Mudsport96's comment about checking the PCM connectors. Pull both off and check for water intrusion and pin fitment. The fan pins are low in the connector and if there's water in there, that's what will be affected.
