could antifreeze in transmission be causing the shuttering between 45/55mph? h
Delco PA
I recently had my atf cooler leak into my radiator. I just replaced and flushed cooling system. I also drained trans and refilled but do not have tools to evacuate fluid from torque converter. The fluid is properly filled and trans shutters horribly once it goes into od. I just had trans rebuilt 18 mo ago and its out of warranty. What can I do to remedy the problem?
OR VietVet
Multnomah Falls
Military
Willamette Valley
Transmissions don't like antifreeze in them. The only chance you got is to try a complete change of the fluid and filter and use an additive for the friction clutches and cross your fingers.
00YukonSLT5.3Rwd
Delco PA
Taking it sunday for a fluid evacuation and refill. Thinking back to my 87 Caprice Classic which blew the atf cooler in the radiator... it also had that same shutter afterwards. I'm just glad I haven't had to drive it.
00YukonSLT5.3Rwd
Delco PA
Update, after 3 at flushes and time, the Trans is fine, thank goodness. Even got all of the Trans fluid out of the cooling system using simple green flushes, then tons of water flushes, and refill with fresh coolant.
YukonCarl
Hi - I just wanted to ask about "flushing the cooling system". I have a 1997 Yukon and no drain plug. Just wondering how you went about draining the system on yours.
GangstaCowboy
I had the same problem. New trans and new radiator. The trans cooler in the radiator was leaking causing water/coolant to get into the transmission.
00YukonSLT5.3Rwd
Delco PA
How I flushed:
Go to Home Depot and get a gallon of Simple Green. After putting the new radiator in, fill cooling system with a half gallon of simple green, the rest water. Run the engine, get it up to operating temp. Make sure thermostat opens and the solution goes through the block as well as radiator.
Shut down and allow to cool slightly. Carefully remove radiator cap, then lower radiator hose. Allow cooling system to dump out in the grass. Simple green is non toxic. You can try to catch in a bucket but good luck. Reattach lower radiator hose, fill with water and repeat above procedure.
After a water flush, use remaining simple green and water in the cooling system. Get it up to temperature, take it for a short drive, and dump the solution.
Now just use water to fill cooling system, run, and dump until it comes out clear. It took me about 10 flushes. After that, remove the overflow bottle and clean thoroughly. Replace the upper and lower radiator hoses, and thermostat. Refill the cooling system with water and antifreeze mix.
I know this seems like a lot of work, but it's the only way to keep from letting the oil build up in the new radiator and heater cores. It also will cause hoses to swell and that's why I recommend replacing them now and not when it blows leaving you stranded.
As for the transmission, it's a similar process. I changed the fluid and filter about 6 times within 500 miles. The shuttering went away and the fluid got clean again. It was foamy and is now pail pink.. not burned, orange or brown.
mello1420
