Crank no start issue
Shane5acosta
I just bought a 99 Tahoe 5.7 vortex. The previous owner claimed he was driving around the farm and ran good. He went inside came back out and it was dead.
I tried to fix it bought new battery, spark plugs, ignition coil, distributor cap and rotor. Checked fuel pressure (58 psi). Checked wiring to starter all looking good with solid connections.
Im stuck any advice/ideas?
Eman85
Dead means?? Does it turn over? Compression? Spark?
S
Shane5acosta
It’s cranking but not turning over and I believe it has compression but I don’t have a compression tester is there a way to test without it? And I’m in the process of replacing everything for the spark last thing would be the starter.
"Cranking" is "turning over." So you have a "crank - no start" condition.
exp500
Fuel pressure low. Any codes set?
S
Shane5acosta
What is it supposed to be at I connected the fuel pressure gauge and it read 58 psi when I put the key into the on position and I don’t believe so im on my way home right now I’ll double check
the ignition control module is a classic to fail on these, causing a inexplicable no start or just "died" while driving
Stevemo70
