Crank no start
S
steveo1
Here's couple videos that didn't post earlier for some reason.. and noid light signal appears to be falling off with the cranking THOUGHTS ?
B-train
Does anyone else seem to hear the HIGH spot in the crank cycle? Or am I just being fooled?
It does appear that the light isn't getting a proper or strong signal. It also appears as though that circuit is being affected by the cranking cycle - watch the light flicker with crank start and end. I wonder if the PCM has an issue for the injector driver. Either that or it's input is bad or weak.
One last thought I have based on the high spot in the cranking test. Have you checked compression on the cylinders? If it's out of time, it should show up as low compression. 90-130 psi after 3 hits is normal from what I've seen historically. You'll need a second set of hands unless you have a long hose for the tester.
But, you did say that the plugs are dry when removed after cranking. Which means no injector pulse to open. You also said that you have good flow from the pump, so supply isn't an issue. I'm not too well versed on what can keep the injectors from firing computer wise though. Would need a bidirectional scanner to perform tests and see real time data.
972sparky
Could be a really bad tank of fuel. I would take the fuel line off just past the filter and run the pump into a glass jar and verify the flow rate and check the fuel for water/debris. Could have plugged all the injectors with junk from the first bad pump and old filter or just bad fuel. There was a gas station near me that got a trash load of fuel and ruined several car's fuel systems, the symptoms were similar to those you described before the first pump replacement. Cost the station a lot of $$$ to fix all the cars that broke. They had to clean all their tanks, lines, filters and pumps as well. It sure seems to be a fuel issue.
S
steveo1
Gonna post a link to video showing scanner results... Standby
S
steveo1
Total 52 codes between the codes listed..
I realize that's a lot..which though would keep it from running...fyi...map sensor was unplugged as a way to diagnose..it's sense been plugged up..
Fless
Super Moderator
Elev 5,280
SWAG: pull the two PCM/ECM connectors and check for cleanliness and good fitment, and water migration.
Reinstall the old crank position sensor.
Test for fuel volume and quality at one of the injectors.
Temporarily ground engine block to negative battery connection. As @rockola1971 asked, what is the voltage on this new battery while cranking?
Shadfrmdabull
